RoundDistance 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 790| 评论: 0|原作者: admin|来自: AutoCAD
指定尺寸单位的舍入。
object.RoundDistance
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:双
一个正实数,表示要将距离舍入到的值。初始值为 0.00。
此属性将所有尺寸标注距离舍入到指定值。例如,如果此属性设置为 0.25,则距离将舍入到最接近的 0.25 单位。如果将此属性设置为 1.0,则维度的距离将舍入到最接近的整数。请注意,小数点后编辑的位数取决于属性或 DIMDEC 系统变量设置的精度。此属性不适用于角度尺寸。PrimaryUnitsPrecision
注意:此属性将覆盖给定维度的 DIMRND 系统变量的值。
Sub Example_RoundDistance()
    ' uses RoundDistance to set the unit display
    ' of the dimension to rounded values
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 10.123: point2(1) = 5: point2(2) = 0
    MsgBox "Press any key to round the dimension unit display to .5"
    ' Round the distance of the dimension to 0.50 of a unit
    dimObj.RoundDistance = 0.5
    MsgBox "Dimension units have been rounded to: " & dimObj.RoundDistance
(defun c:Example_RoundDistance()
    ;; uses RoundDistance to set the unit display
    ;; of the dimension to rounded values
    ;; Define the dimension
          point2 (vlax-3d-point 10.123 5 0)
    (vla-ZoomAll acadObj)
    (alert "Dimensions value will now be rounded to the nearest 0.50 of a unit")
    ;; Round the distance of the dimension to 0.50 of a unit
    (vla-put-RoundDistance dimObj 0.5)
    (alert (strcat "Dimension units have been rounded to: " (rtos (vla-get-RoundDistance dimObj) 2)))
GMT+8, 2026-10-27 08:59
