Rotation 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 644| 评论: 0|原作者: admin|来自: AutoCAD
指定对象的旋转角度。
只读:不
类型:Double(ACAD_ANGLE 类型的 OLE 对象除外)
以弧度为单位的旋转角度。
旋转角度相对于物体 WCS 的 X 轴,从 Z 轴向下看原点时,正角逆时针方向。
栅格:要以指定的旋转方式显示光栅图像,请将属性设置为 。ShowRotationTrue
文本:对于属性设置为 或 的文本,旋转角度是只读的。AlignmentacAlignmentAlignedacAlignmentFit
文本旋转角度
尺寸线角度
Sub Example_Rotation()
    ' This example creates a text object in model space.
    ' It then changes the Rotation of the text object.
    Dim textObj As AcadText
    Dim textString As String
    Dim height As Double
    ' Define the text object
    textString = "Hello, World."
    insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0
    height = 0.5
    ' Create the text object in model space
    Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
    ZoomAll
    MsgBox "The Rotation is " & textObj.rotation, vbInformation, "Rotation Example"
    ' Change the value of the Rotation to 45 degrees (.707 radians)
    textObj.rotation = 0.707
    ZoomAll
    MsgBox "The Rotation is set to " & textObj.rotation, vbInformation, "Rotation Example"
(defun c:Example_Rotation()
    ;; This example creates a text object in model space.
    ;; It then changes the Rotation of the text object.
    ;; Define the text object
    (setq textString "Hello, World."
          insertionPoint (vlax-3d-point 3 3 0)
          height 0.5)
    ;; Create the text object in model space
    (setq textObj (vla-AddText modelSpace textString insertionPoint height))
    (vla-ZoomAll acadObj)
    (alert (strcat "The Rotation is " (rtos (vla-get-Rotation textObj) 2)))
    ;; Change the value of the Rotation to 45 degrees (.707 radians)
    (vla-put-Rotation textObj 0.707)
    (alert (strcat "The Rotation is set to " (rtos (vla-get-Rotation textObj) 2)))
GMT+8, 2026-10-27 06:55
