RenderSmoothness 属性 (ActiveX)
指定着色、渲染和隐藏的线删除对象的平滑度。 支持的平台:仅限 Windows 属性值只读:不 类型:双 有效范围为 0.01 到 10.0。 言论此属性的初始值为 0.5。若要提高性能,请在绘图时将此值设置为 1 或更小。 注意:此属性的值存储在 FACETRES 系统变量中。
例子VBA: Sub Example_RenderSmoothness()
' RenderSmoothness. It then changes the value, and finally
Dim currRenderSmoothness As Double
Dim newRenderSmoothness As Double
' Retrieve the current RenderSmoothness value
currRenderSmoothness = ThisDrawing.preferences.RenderSmoothness
MsgBox "The current value for RenderSmoothness is " & currRenderSmoothness, vbInformation, "RenderSmoothness Example"
' Change the value for RenderSmoothness
newRenderSmoothness = 2.5
ThisDrawing.preferences.RenderSmoothness = newRenderSmoothness
MsgBox "The new value for RenderSmoothness is " & newRenderSmoothness, vbInformation, "RenderSmoothness Example"
' Reset RenderSmoothness to its original value
ThisDrawing.preferences.RenderSmoothness = currRenderSmoothness
MsgBox "The RenderSmoothness value is reset to " & currRenderSmoothness, vbInformation, "RenderSmoothness Example"
可视化 LISP: (vl-load-com)
(defun c:Example_RenderSmoothness()
;; RenderSmoothness. It then changes the value, and finally
(setq preferences (vla-get-Preferences doc))
;; Retrieve the current RenderSmoothness value
(setq currRenderSmoothness (vla-get-RenderSmoothness preferences))
(alert (strcat "The current value for RenderSmoothness is " (rtos currRenderSmoothness 2)))
;; Change the value for RenderSmoothness
(setq newRenderSmoothness 2.5)
(vla-put-RenderSmoothness preferences newRenderSmoothness)
(alert (strcat "The new value for RenderSmoothness is " (rtos newRenderSmoothness 2)))
;; Reset RenderSmoothness to its original value
(vla-put-RenderSmoothness preferences currRenderSmoothness)
(alert (strcat "The RenderSmoothness value is reset to " (rtos currRenderSmoothness 2)))
GMT+8, 2026-10-27 13:08
