RadiusRatio 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 715| 评论: 0|原作者: admin|来自: AutoCAD
指定椭圆的长轴与短轴之比。
object.RadiusRatio
类型:椭圆
此属性应用于的对象。
只读:不
类型:双
圆弧或圆的半径比。
如果输入的短轴长于长轴,则椭圆将为圆形,因为半径比不能大于 1.0。(半径比为 1.0 定义一个圆。
半径比 = 0.25
半径比 = 0.75
Sub Example_RadiusRatio()
    ' This example creates an ellipse and finds the radius ratio
    ' for that ellipse. It then changes the radius ratio to 0.75.
    Dim ellObj As AcadEllipse
    Dim majAxis(0 To 2) As Double
    Dim center(0 To 2) As Double
    Dim radRatio As Double
    ' Create an ellipse in model space
    center(0) = 5#: center(1) = 5#: center(2) = 0#
    majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
    radRatio = 0.3
    Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
    ZoomAll
    MsgBox "This ellipse has a radius ratio of " & ellObj.RadiusRatio, vbInformation, "RadiusRatio Example"
    ' Change the radius ratio of the ellipse
    radRatio = 0.75
    ellObj.RadiusRatio = radRatio
    ellObj.Update
    MsgBox "The ellipse has been udpated with the radius ratio of " & ellObj.RadiusRatio, vbInformation, "RadiusRatio Example"
(defun c:Example_RadiusRatio()
    ;; This example creates an ellipse and finds the radius ratio
    ;; for that ellipse. It then changes the radius ratio to 0.75.
    ;; Create an ellipse in model space
    (setq center (vlax-3d-point 5 5 0)
          majAxis (vlax-3d-point 10 20 0)
          radRatio 0.3)
    (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
    (vla-ZoomAll acadObj)
    (alert (strcat "This ellipse has a radius ratio of " (rtos (vla-get-RadiusRatio ellObj) 2)))
    ;; Change the radius ratio of the ellipse
    (vla-put-RadiusRatio ellObj 0.75)
    (vla-Update ellObj)
    (alert (strcat "The ellipse has been udpated with the radius ratio of " (rtos (vla-get-RadiusRatio ellObj) 2)))
GMT+8, 2026-10-27 09:19
