ProxyImage 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 842| 评论: 0|原作者: admin|来自: AutoCAD
控制在图形中在第三方应用程序中创建的对象的显示。
object.ProxyImage
类型:PreferencesOpenSave
此属性应用于的对象。
只读:不
类型:枚举acProxyImage
  • acProxyNotShow
  • acProxyShow
  • acProxyBoundingBox
此属性的初始值为 。acProxyShow
Sub Example_ProxyImage()
    ' ProxyImage. It then changes the value, and finally
    Dim currProxyImage As Integer
    Dim constant As String
    Dim newConstant As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current ProxyImage value
    currProxyImage = preferences.OpenSave.ProxyImage
    constant = Choose(currProxyImage + 1, "acProxyNotShow", "acProxyShow", "acProxyBoundingBox")
    MsgBox "The current value for ProxyImage is " & constant, vbInformation, "ProxyImage Example"
    ' Change the value for ProxyImage
    newConstant = "acProxyBoundingBox"
    preferences.OpenSave.ProxyImage = acProxyBoundingBox
    MsgBox "The new value for ProxyImage is " & newConstant, vbInformation, "ProxyImage Example"
    ' Reset ProxyImage to its original value
    preferences.OpenSave.ProxyImage = currProxyImage
    MsgBox "The ProxyImage value is reset to " & constant, vbInformation, "ProxyImage Example"
(defun c:Example_ProxyImage()
    ;; ProxyImage. It then changes the value, and finally
    ;; Retrieve the current ProxyImage value
    (setq currProxyImage (vla-get-ProxyImage (vla-get-OpenSave preferences)))
    (setq constant (cond
                       ((= currProxyImage 0) "acProxyNotShow")
                       ((= currProxyImage 1) "acProxyShow")
                       ((= currProxyImage 2) "acProxyBoundingBox")
    (alert (strcat "The current value for ProxyImage is " constant))
    ;; Change the value for ProxyImage
    (setq newConstant "acProxyBoundingBox")
    (vla-put-ProxyImage (vla-get-OpenSave preferences) acProxyBoundingBox)
    (alert (strcat "The new value for ProxyImage is " newConstant))
    ;; Reset ProxyImage to its original value
    (vla-put-ProxyImage (vla-get-OpenSave preferences) currProxyImage)
    (alert (strcat "The ProxyImage value is reset to " constant))
GMT+8, 2026-10-27 04:59
