Profiles 属性 (ActiveX)
获取 PreferencesProfiles 对象。 支持的平台:仅限 Windows 言论该对象保存存储在注册表中的“选项”对话框的“配置文件”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesProfilesDatabasePreferences 例子VBA: Sub Example_Profiles()
' This example obtains a reference to the Profiles Preferences object
' from the Application Preferences object, and reads one of the Profiles
' preferences
Dim ACADPref As AcadPreferencesProfiles
' Obtain a reference to the Profiles Preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Profiles
MsgBox "You now have access to the properties and methods of the Profiles Preferences object!"
MsgBox "The Profiles preference ActiveProfile is set to: " & ACADPref.ActiveProfile
可视化 LISP: (vl-load-com)
(defun c:Example_Profiles()
;; This example obtains a reference to the Profiles Preferences object
;; from the Application Preferences object, and reads one of the Profiles
;; preferences
;; Obtain a reference to the Profiles Preferences object
(alert "You now have access to the properties and methods of the Profiles Preferences object!")
(alert (strcat "The Profiles preference ActiveProfile is set to: " (vla-get-ActiveProfile (vla-get-Profiles preferences))))
GMT+8, 2026-11-15 12:51
