ProductOfInertia 属性 (ActiveX)
获取固体或区域的惯性乘积。 支持的平台:仅限 Windows 属性值只读:是的 类型:变体(双打的三元素阵列) 在当前坐标系上计算的 X、Y 和 Z 坐标。 言论惯性的乘积以 X、Y 和 Z 坐标的形式返回,定义为变体。它是根据当前坐标系计算的。 例子VBA: Sub Example_ProductOfInertia()
' This example creates a box in model space.
' It then returns the ProductOfInertia for that box.
Dim boxObj As Acad3DSolid
Dim length As Double, width As Double, height As Double
Dim center(0 To 2) As Double
' Define the box
center(0) = 5#: center(1) = 5#: center(2) = 0
length = 5#: width = 7: height = 10#
' Create the box (3DSolid) object in model space
Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
' Change the viewing direction of the viewport to better see the box
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
ZoomAll
' Return the ProductOfInertia for the box
Dim ProductOfInertia As Variant
ProductOfInertia = boxObj.ProductOfInertia
MsgBox "The ProductOfInertia for the box is " & ProductOfInertia(0) & ", " & ProductOfInertia(1) & ", " & ProductOfInertia(2), , "ProductOfInertia Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ProductOfInertia()
;; This example creates a box in model space.
;; It then returns the ProductOfInertia for that box.
;; Define the box
(setq center (vlax-3d-point 5 5 0)
boxLength 5
boxWidth 7
boxHeight 10)
;; Create the box (3DSolid) object in model space
(setq boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight))
;; Change the viewing direction of the viewport to better see the box
(setq NewDirection (vlax-3d-point -1 -1 1))
(setq activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport NewDirection)
(vla-put-ActiveViewport doc activeViewport)
(vla-ZoomAll acadObj)
;; Return the ProductOfInertia for the box
(setq ProductOfInertia (vlax-variant-value (vla-get-ProductOfInertia boxObj)))
(alert (strcat "The ProductOfInertia for the box is "
(rtos (vlax-safearray-get-element ProductOfInertia 0) 2) ", "
(rtos (vlax-safearray-get-element ProductOfInertia 1) 2) ", "
(rtos (vlax-safearray-get-element ProductOfInertia 2) 2)))
GMT+8, 2026-10-27 05:46
