PrintSpoolExecutable 属性 (ActiveX)
指定要用于打印后台处理的应用程序。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 打印后台打印应用程序。 言论此属性包含用于 AutoSpool 的打印后台处理可执行文件的驱动器、路径和应用程序名称。 例子VBA: Sub Example_PrintSpoolExecutable()
' PrintSpoolExecutable. It then changes the value, and finally
Dim currPrintSpoolExecutable As String
Dim newPrintSpoolExecutable As String
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current PrintSpoolExecutable value
currPrintSpoolExecutable = preferences.Files.PrintSpoolExecutable
MsgBox "The current value for PrintSpoolExecutable is " & currPrintSpoolExecutable, vbInformation, "PrintSpoolExecutable Example"
' Change the value for PrintSpoolExecutable
newPrintSpoolExecutable = "TestPrintSpoolExecutable"
preferences.Files.PrintSpoolExecutable = newPrintSpoolExecutable
MsgBox "The new value for PrintSpoolExecutable is " & newPrintSpoolExecutable, vbInformation, "PrintSpoolExecutable Example"
' Reset PrintSpoolExecutable to its original value
preferences.Files.PrintSpoolExecutable = currPrintSpoolExecutable
MsgBox "The PrintSpoolExecutable value is reset to " & currPrintSpoolExecutable, vbInformation, "PrintSpoolExecutable Example"
可视化 LISP: (vl-load-com)
(defun c:Example_PrintSpoolExecutable()
;; PrintSpoolExecutable. It then changes the value, and finally
;; Retrieve the current PrintSpoolExecutable value
(setq currPrintSpoolExecutable (vla-get-PrintSpoolExecutable (vla-get-Files preferences)))
(alert (strcat "The current value for PrintSpoolExecutable is " currPrintSpoolExecutable))
;; Change the value for PrintSpoolExecutable
(setq newPrintSpoolExecutable "TestPrintSpoolExecutable")
(vla-put-PrintSpoolExecutable (vla-get-Files preferences) newPrintSpoolExecutable)
(alert (strcat "The new value for PrintSpoolExecutable is " newPrintSpoolExecutable))
;; Reset PrintSpoolExecutable to its original value
(vla-put-PrintSpoolExecutable (vla-get-Files preferences) currPrintSpoolExecutable)
(alert (strcat "The PrintSpoolExecutable value is reset to " currPrintSpoolExecutable))
GMT+8, 2026-10-27 04:12
