PrintSpoolerPath 属性 (ActiveX)
指定打印后台打印文件的目录。AutoCAD 将打印到此位置。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 打印后台打印文件的目录。 言论没有其他评论。 例子VBA: Sub Example_PrintSpoolerPath()
' PrintSpoolerPath. It then changes the value, and finally
Dim currPrintSpoolerPath As String
Dim newPrintSpoolerPath As String
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current PrintSpoolerPath value
currPrintSpoolerPath = preferences.Files.PrintSpoolerPath
MsgBox "The current value for PrintSpoolerPath is " & currPrintSpoolerPath, vbInformation, "PrintSpoolerPath Example"
' Change the value for PrintSpoolerPath
newPrintSpoolerPath = "TestPrintSpoolerPath"
preferences.Files.PrintSpoolerPath = newPrintSpoolerPath
MsgBox "The new value for PrintSpoolerPath is " & newPrintSpoolerPath, vbInformation, "PrintSpoolerPath Example"
' Reset PrintSpoolerPath to its original value
preferences.Files.PrintSpoolerPath = currPrintSpoolerPath
MsgBox "The PrintSpoolerPath value is reset to " & currPrintSpoolerPath, vbInformation, "PrintSpoolerPath Example"
可视化 LISP: (vl-load-com)
(defun c:Example_PrintSpoolerPath()
;; PrintSpoolerPath. It then changes the value, and finally
;; Retrieve the current PrintSpoolerPath value
(setq currPrintSpoolerPath (vla-get-PrintSpoolerPath (vla-get-Files preferences)))
(alert (strcat "The current value for PrintSpoolerPath is " currPrintSpoolerPath))
;; Change the value for PrintSpoolerPath
(setq newPrintSpoolerPath "TestPrintSpoolerPath")
(vla-put-PrintSpoolerPath (vla-get-Files preferences) newPrintSpoolerPath)
(alert (strcat "The new value for PrintSpoolerPath is " newPrintSpoolerPath))
;; Reset PrintSpoolerPath to its original value
(vla-put-PrintSpoolerPath (vla-get-Files preferences) currPrintSpoolerPath)
(alert (strcat "The PrintSpoolerPath value is reset to " currPrintSpoolerPath))
GMT+8, 2026-10-27 09:00
