PrinterStyleSheetPath 属性 (ActiveX)
指定打印机样式表文件的位置。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 打印机样式表文件的驱动器和路径。 言论使用分号 (;) 分隔多个目录;但是,不要以分号结束字符串。 例子VBA: Sub Example_PrinterStyleSheetPath()
' This example reads and modifies the preference value that controls
' the location for printer style sheet files.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesFiles
' Get the files preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Files
originalValue = ACADPref.PrinterStyleSheetPath
MsgBox "The PrinterStyleSheetPath preference is set to: " & originalValue
' Modify the PrinterStyleSheetPath preference by changing the path to "C:\"
ACADPref.PrinterStyleSheetPath = "C:\"
newValue = ACADPref.PrinterStyleSheetPath
MsgBox "The PrinterStyleSheetPath preference has been set to: " & newValue
' this preference in effect
ACADPref.PrinterStyleSheetPath = originalValue
MsgBox "The PrinterStyleSheetPath preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_PrinterStyleSheetPath()
;; This example reads and modifies the preference value that controls
;; the location for printer style sheet files.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-PrinterStyleSheetPath (vla-get-Files preferences)))
(alert (strcat "The PrinterStyleSheetPath preference is set to: " originalValue))
;; Modify the PrinterStyleSheetPath preference by changing the path to "C:\\"
(vla-put-PrinterStyleSheetPath (vla-get-Files preferences) "C:\\")
(setq newValue (vla-get-PrinterStyleSheetPath (vla-get-Files preferences)))
(alert (strcat "The PrinterStyleSheetPath preference has been set to: " newValue))
;; this preference in effect
(vla-put-PrinterStyleSheetPath (vla-get-Files preferences) originalValue)
(alert (strcat "The PrinterStyleSheetPath preference was reset back to: " originalValue))
GMT+8, 2026-10-27 14:29
