PrinterSpoolAlert 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 646| 评论: 0|原作者: admin|来自: AutoCAD
指定当由于与 I/O 端口冲突而必须通过系统打印机对设备的输出进行假脱机处理时,是否向用户发出警报。
object.PrinterSpoolAlert
类型:首选项输出
此属性应用于的对象。
只读:不
类型:枚举acPrinterSpoolAlert
  • acPrinterAlwaysAlert:始终发出警报并记录错误。
  • acPrinterAlertOnce:仅对第一个错误发出警报并记录所有错误。
  • acPrinterNeverAlertLogOnce:从不发出警报,但记录所有错误。
  • acPrinterNeverAlert:从不发出警报,也不记录任何错误。
此属性的初始值为 。acPrinterAlwaysAlert
Sub Example_PrinterSpoolAlert()
    ' This example reads and modifies the PrinterSpoolAlert
    ' preference value.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesOutput
    Dim originalValue As Integer
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Output
    originalValue = ACADPref.PrinterSpoolAlert
    MsgBox "The PrinterSpoolAlert preference is set to: " & originalValue
    ' Modify the PrinterSpoolAlert preference by toggling the value
    ACADPref.PrinterSpoolAlert = acPrinterNeverAlert
    MsgBox "The PrinterSpoolAlert preference has been set to: " & ACADPref.PrinterSpoolAlert
    ACADPref.PrinterSpoolAlert = originalValue
    MsgBox "The PrinterSpoolAlert preference was reset back to: " & originalValue
(defun c:Example_PrinterSpoolAlert()
    ;; This example reads and modifies the PrinterSpoolAlert
    ;; preference value.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-PrinterSpoolAlert (vla-get-Output preferences)))
    (alert (strcat "The PrinterSpoolAlert preference is set to: " (itoa originalValue)))
    ;; Modify the PrinterSpoolAlert preference by toggling the value
    (vla-put-PrinterSpoolAlert (vla-get-Output preferences) acPrinterNeverAlert)
    (alert (strcat "The PrinterSpoolAlert preference has been set to: " (itoa (vla-get-PrinterSpoolAlert (vla-get-Output preferences)))))
    (vla-put-PrinterSpoolAlert (vla-get-Output preferences) originalValue)
    (alert (strcat "The PrinterSpoolAlert preference was reset back to: " (itoa (vla-get-PrinterSpoolAlert (vla-get-Output preferences)))))
GMT+8, 2026-10-27 11:13
