Preferences 属性 (ActiveX)
获取 Preferences 对象。 支持的平台:仅限 Windows 言论该对象保存“选项”对话框中的选项,这些选项驻留在注册表中。可以通过对象找到驻留在图形中的选项。PreferencesDatabasePreferences 例子VBA: Sub Example_Preferences()
' LogFilePath from the preferences object.
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current LogFilePath value
MsgBox "The current value for LogFilePath is " & preferences.Files.LogFilePath, , "Preferences Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Preferences()
;; LogFilePath from the preferences object.
;; Retrieve the current LogFilePath value
(alert (strcat "The current value for LogFilePath is " (vla-get-LogFilePath (vla-get-Files preferences))))
GMT+8, 2026-10-27 00:39
