PostScriptPrologFile 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 685| 评论: 0|原作者: admin|来自: AutoCAD
指定 acad.psf 文件中自定义 prolog 部分的名称。
object.PostScriptPrologFile
类型:PreferencesFiles
此属性应用于的对象。
只读:
类型:字符串
执行 PSOUT 时要使用的 acad.psf 文件的 postscript prolog 部分的名称。
prolog 截面与 PSOUT AutoCAD 命令一起使用,以自定义生成的输出。有关详细信息,请参见 AutoCAD 文档。
注意:此属性的值存储在 PSPROLOG 系统变量中。
Sub Example_PostScriptPrologFile()
    ' PostScriptPrologFile. It then changes the value, and finally
    Dim currPostScriptPrologFile As String
    Dim newPostScriptPrologFile As String
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current PostScriptPrologFile value
    currPostScriptPrologFile = preferences.Files.PostScriptPrologFile
    If currPostScriptPrologFile = "" Then
        MsgBox "PostScriptPrologFile is not currently set.", vbInformation, "PostScriptPrologFile Example"
    Else
        MsgBox "The current value for PostScriptPrologFile is " & currPostScriptPrologFile, vbInformation, "PostScriptPrologFile Example"
    End If
    ' Change the value for PostScriptPrologFile
    newPostScriptPrologFile = "TestPostScriptPrologFile"
    preferences.Files.PostScriptPrologFile = newPostScriptPrologFile
    MsgBox "The new value for PostScriptPrologFile is " & newPostScriptPrologFile, vbInformation, "PostScriptPrologFile Example"
    ' Reset PostScriptPrologFile to its original value
    preferences.Files.PostScriptPrologFile = currPostScriptPrologFile
        MsgBox "PostScriptPrologFile is reset to NULL.", vbInformation, "PostScriptPrologFile Example"
    Else
        MsgBox "The PostScriptPrologFile value is reset to " & currPostScriptPrologFile, vbInformation, "PostScriptPrologFile Example"
    End If
(defun c:Example_PostScriptPrologFile()
    ;; PostScriptPrologFile. It then changes the value, and finally
    ;; Retrieve the current PostScriptPrologFile value
    (setq currPostScriptPrologFile (vla-get-PostScriptPrologFile (vla-get-Files preferences)))
    (if (= currPostScriptPrologFile "")
        (alert "PostScriptPrologFile is not currently set.")
        (alert (strcat "The current value for PostScriptPrologFile is " currPostScriptPrologFile))
    ;; Change the value for PostScriptPrologFile
    (setq newPostScriptPrologFile "TestPostScriptPrologFile")
    (vla-put-PostScriptPrologFile (vla-get-Files preferences) newPostScriptPrologFile)
    (alert (strcat "The new value for PostScriptPrologFile is " newPostScriptPrologFile))
    ;; Reset PostScriptPrologFile to its original value
    (vla-put-PostScriptPrologFile (vla-get-Files preferences) currPostScriptPrologFile)
        (alert "PostScriptPrologFile is reset to NULL.")
        (alert (strcat "The PostScriptPrologFile value is reset to " currPostScriptPrologFile))
GMT+8, 2026-9-15 05:23
