PolarTrackingVector 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 906| 评论: 0|原作者: admin|来自: AutoCAD
切换极坐标跟踪矢量的显示。
object.PolarTrackingVector
类型:首选项起草
此属性应用于的对象。
只读:不
类型:布尔
  • True:启用极坐标跟踪矢量。
  • False:禁用极坐标跟踪矢量。
此属性的初始值为 。True
注意:此属性的值存储在 TRACKPATH 系统变量中。
Sub Example_PolarTrackingVector()
    ' This example reads and modifies the preference value that controls
    ' the display of polar tracking vectors.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesDrafting
    ' Get the drafting preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Drafting
    originalValue = ACADPref.PolarTrackingVector
    MsgBox "The PolarTrackingVector preference is set to: " & originalValue
    ' Modify the PolarTrackingVector preference by toggling the value
    ACADPref.PolarTrackingVector = Not (originalValue)
    newValue = ACADPref.PolarTrackingVector
    MsgBox "The PolarTrackingVector preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.PolarTrackingVector = originalValue
    MsgBox "The PolarTrackingVector preference was reset back to: " & originalValue
(defun c:Example_PolarTrackingVector()
    ;; This example reads and modifies the preference value that controls
    ;; the display of polar tracking vectors.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    Set ACADPref = ThisDrawing.Application.preferences.Drafting
    (setq originalValue (vla-get-PolarTrackingVector (vla-get-Drafting preferences)))
    (alert (strcat "The PolarTrackingVector preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PolarTrackingVector preference by toggling the value
    (vla-put-PolarTrackingVector (vla-get-Drafting preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-PolarTrackingVector (vla-get-Drafting preferences)))
    (alert (strcat "The PolarTrackingVector preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-PolarTrackingVector (vla-get-Drafting preferences) originalValue)
    (alert (strcat "The PolarTrackingVector preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 04:53
