PlotViewportBorders 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 863| 评论: 0|原作者: admin|来自: AutoCAD
指定是否要打印视口边框。
object.PlotViewportBorders
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:布尔
  • True:绘制视口边框。
  • False:不绘制视口边框。
Sub Example_PlotViewportBorders()
    ' This example reads and modifies the PlotViewportBorders
    ' Layout value.
    ' When finished, this example resets the  value back to
    ' its original value.
    Dim ACADLayout As ACADLayout
    Dim originalValue As Boolean
    ' Get the layout object
    Set ACADLayout = ThisDrawing.ActiveLayout
    originalValue = ACADLayout.PlotViewportBorders
    MsgBox "The PlotViewportBorders value is set to: " & originalValue
    ' Modify the PlotViewportBorders preference by toggling the value
    ACADLayout.PlotViewportBorders = Not ACADLayout.PlotViewportBorders
    MsgBox "The PlotViewportBorders preference has been set to: " & ACADLayout.PlotViewportBorders
    ACADLayout.PlotViewportBorders = originalValue
    MsgBox "The PlotViewportBorders preference was reset back to: " & originalValue
(defun c:Example_PlotViewportBorders()
    ;; This example reads and modifies the PlotViewportBorders
    ;; Layout value.
    ;; When finished, this example resets the  value back to
    ;; its original value.
    ;; Get the layout object
    (setq ACADLayout (vla-get-ActiveLayout doc))
    (setq originalValue (vla-get-PlotViewportBorders ACADLayout))
    (alert (strcat "The PlotViewportBorders value is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PlotViewportBorders preference by toggling the value
    (vla-put-PlotViewportBorders ACADLayout (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-PlotViewportBorders ACADLayout))
    (alert (strcat "The PlotViewportBorders preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    (vla-put-PlotViewportBorders ACADLayout originalValue)
    (alert (strcat "The PlotViewportBorders preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 13:07
