Plottable 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 893| 评论: 0|原作者: admin|来自: AutoCAD
指定图层是否可打印。
object.Plottable
类型:图层
此属性应用于的对象。
只读:
类型:布尔
  • True:图层是可打印的。
  • False:图层不可打印。
Sub Example_Plottable()
    ' This example creates a new layer called "New_Layer".  It then uses
    ' the Plottable property of each Layer to display whether or not that layer
    ' is plottable.  The user has the ability to toggle the plottable state
    ' for each layer, and the final plottable status for all layers is displayed.
    Dim layerObj As AcadLayer, tempLayer As AcadLayer
    Dim msg As String
    ' Add the layer to the layers collection
    Set layerObj = ThisDrawing.Layers.Add("New_Layer")
    ' Make the new layer the active layer for the drawing
    ThisDrawing.ActiveLayer = layerObj
    ' Cycle through the layers and allow user to make them plottable or not
    For Each tempLayer In ThisDrawing.Layers
        If tempLayer.Plottable Then     ' Determine if this layer is plottable
            If MsgBox("The layer '" & tempLayer.name & "' will plot.  Would you like to turn off plotting for this layer?", vbYesNo & vbQuestion) = vbYes Then
                tempLayer.Plottable = False     ' Change plottable state
            End If
        Else
            If MsgBox("The layer '" & tempLayer.name & "' will not plot.  Would you like to turn on plotting for this layer?", vbYesNo & vbQuestion) = vbYes Then
                tempLayer.Plottable = True      ' Change plottable state
            End If
        End If
    Next
    ' Display the new plottable status of the layers in this drawing
            msg = msg & "The layer '" & tempLayer.name & "' will plot." & vbCrLf
        Else
            msg = msg & "The layer '" & tempLayer.name & "' will not plot." & vbCrLf
        End If
    Next
    MsgBox msg
(defun c:Example_Plottable()
    ;; This example creates a new layer called "New_Layer".  It then uses
    ;; the Plottable property of each Layer to display whether or not that layer
    ;; is plottable.  The user has the ability to toggle the plottable state
    ;; for each layer, and the final plottable status for all layers is displayed.
    ;; Add the layer to the layers collection
    (setq layerObj (vla-Add (vla-get-Layers doc) "New_Layer"))
    ;; Make the new layer the active layer for the drawing
    (vla-put-ActiveLayer doc layerObj)
    ;; Cycle through the layers and allow user to make them plottable or not
    (vlax-for tempLayer (vla-get-Layers doc)
        (if (= (vla-get-Plottable tempLayer) :vlax-true)     ;; Determine if this layer is plottable
            (progn
                (alert (strcat "The layer '" (vla-get-Name tempLayer) "' set to plot."))
                (vla-put-Plottable tempLayer :vlax-false)     ;; Change plottable state
                (alert (strcat "The layer '" (vla-get-Name tempLayer) "' now set not to plot."))
            (progn
                (alert (strcat "The layer '" (vla-get-Name tempLayer) "' set not to plot."))
                (vla-put-Plottable tempLayer :vlax-true)     ;; Change plottable state
                (alert (strcat "The layer '" (vla-get-Name tempLayer) "' now set to plot."))
    (setq msg "")
    ;; Display the new plottable status of the layers in this drawing
            (setq msg (strcat msg "The layer '" (vla-get-Name tempLayer) "' will plot.\n"))
            (setq msg (strcat msg "The layer '" (vla-get-Name tempLayer) "' will not plot.\n"))
    (alert msg)
GMT+8, 2026-9-15 04:34
