PlotPolicy 属性 (ActiveX)
确定在创建新图形时,对象的颜色属性是否与其打印样式名称相关联。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acPlotPolicy
言论此属性的初始值为 。acPolicyNamed 如果要更改图形的默认打印样式行为,请在打开或创建图形之前输入 or 或。使用此特性更改默认打印样式行为仅影响新图形或在早期版本的 AutoCAD 中创建的图形,这些图形从未以 AutoCAD 2000 或更高版本格式保存。此设置随图形一起保存。您可以使用迁移实用程序将图形的默认行为从保存后更改为。但是,一旦将图形的 acPolicyNamed 作为默认行为保存,则无法将其更改为 。acPolicyLegacyacPolicyNamedacPolicyLegacyacPolicyNamedacPolicyLegacy 例子VBA: Sub Example_PlotPolicy()
' This example reads and modifies the PlotPolicy
' preference value.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesOutput
Dim originalValue As Integer
' Get the user preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Output
originalValue = ACADPref.PlotPolicy
MsgBox "The PlotPolicy preference is set to: " & originalValue
' Modify the PlotPolicy preference by toggling the value
ACADPref.PlotPolicy = acPolicyNamed
MsgBox "The PlotPolicy preference has been set to: " & ACADPref.PlotPolicy
ACADPref.PlotPolicy = originalValue
MsgBox "The PlotPolicy preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_PlotPolicy()
;; This example reads and modifies the PlotPolicy
;; preference value.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-PlotPolicy (vla-get-Output preferences)))
(alert (strcat "The PlotPolicy preference is set to: " (itoa originalValue)))
;; Modify the PlotPolicy preference by toggling the value
(vla-put-PlotPolicy (vla-get-Output preferences) acPolicyNamed)
(alert (strcat "The PlotPolicy preference has been set to: " (itoa (vla-get-PlotPolicy (vla-get-Output preferences)))))
(vla-put-PlotPolicy (vla-get-Output preferences) originalValue)
(alert (strcat "The PlotPolicy preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-11-15 12:36
