PlotOrigin 属性 (ActiveX)
在 WCS 坐标中指定布局或打印配置的原点。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双精度的双元素数组) X 和 Y 值表示相对于媒体左下角的原点。 言论原点与介质边缘的偏移量为纸张边距。使用该方法查询边距。原点以毫米为单位。GetPaperMargins 在重新生成图形之前,对此属性的更改将不可见。使用该方法重新生成图形。Regen 例子VBA: Sub Example_PlotOrigin()
' This example reads and modifies the PlotOrigin
' Layout value.
' When finished, this example resets the value back to
' its original value.
Dim ACADLayout As ACADLayout
Dim originalValue As Variant
Dim newValue(0 To 1) As Double
' Get the layout object
Set ACADLayout = ThisDrawing.ActiveLayout
originalValue = ACADLayout.PlotOrigin
MsgBox "The PlotOrigin value is set to: " & originalValue(0) & " ," & originalValue(1)
' Modify the PlotOrigin preference by toggling the value
newValue(0) = originalValue(0) + 20
newValue(1) = originalValue(1) - 20
ACADLayout.PlotOrigin = newValue
MsgBox "The PlotOrigin value is set to: " & newValue(0) & " ," & newValue(1)
ACADLayout.PlotOrigin = originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_PlotOrigin()
;; This example reads and modifies the PlotOrigin
;; Layout value.
;; When finished, this example resets the value back to
;; its original value.
;; Get the layout object
(setq ACADLayout (vla-get-ActiveLayout doc))
(setq originalValue (vlax-variant-value (vla-get-PlotOrigin ACADLayout)))
(alert (strcat "The PlotOrigin value is set to: " (rtos (vlax-safearray-get-element originalValue 0) 2) " ,"
(rtos (vlax-safearray-get-element originalValue 1) 2)))
;; Modify the PlotOrigin preference by toggling the value
(setq newValue (vlax-make-safearray vlax-vbDouble '(0 . 1)))
(vlax-safearray-fill newValue (list (+ (vlax-safearray-get-element originalValue 0) 20)
(- (vlax-safearray-get-element originalValue 1) 20)))
(vla-put-PlotOrigin ACADLayout newValue)
(alert (strcat "The PlotOrigin value is set to: " (rtos (vlax-safearray-get-element newValue 0) 2) " ,"
(rtos (vlax-safearray-get-element newValue 1) 2)))
(vla-put-PlotOrigin ACADLayout originalValue)
GMT+8, 2026-10-27 04:13
