PlotHidden 属性 (ActiveX)
指定在打印过程中是否要隐藏对象。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性指定是否通过隐藏线算法处理图纸空间中的对象。请注意,此属性不会影响浮动模型空间视口内的对象。 例子VBA: Sub Example_PlotHidden()
' This example will access the Layouts collection for the current drawing
' and display whether the objects for each layout are to be hidden during a plot.
' It will then toggle the state of PlotHidden for "Layout1" and re-display the
' PlotHidden state for each Layout.
Dim Layouts As AcadLayouts, Layout As ACADLayout
Dim msg As String
Dim IsHidden As String
' Get layouts collection from document object
Set Layouts = ThisDrawing.Layouts
' Display current hidden information
GoSub DISPLAY
' Toggle object hidden state for Layout1
Layouts("Layout1").PlotHidden = Not (Layouts("Layout1").PlotHidden)
' Display new hidden information
GoSub DISPLAY
Exit Sub
DISPLAY:
msg = "" ' Clear message
' Determine whether the objects for each layout are hidden during a plot
For Each Layout In Layouts
' Are these objects hidden?
IsHidden = IIf(Layout.PlotHidden, " are hidden ", " are not hidden ")
' Format for display
msg = msg & "Objects for " & Layout.name & IsHidden & "during a plot." & vbCrLf
Next
' Display layout information
MsgBox msg
Return
可视化 LISP: (vl-load-com)
(defun c:Example_PlotHidden()
;; This example will access the Layouts collection for the current drawing
;; and display whether the objects for each layout are to be hidden during a plot.
;; It will then toggle the state of PlotHidden for "Layout1" and re-display the
;; PlotHidden state for each Layout.
;; Get layouts collection from document object
(setq Layouts (vla-get-Layouts doc))
;; Display current hidden information
(setq msg "")
;; Determine whether the objects for each layout are hidden during a plot
(vlax-for Layout Layouts
;; Are these objects hidden?
(setq IsHidden (if (= (vla-get-PlotHidden Layout) :vlax-true) " are hidden " " are not hidden "))
;; Format for display
(setq msg (strcat msg "Objects for " (vla-get-Name Layout) IsHidden "during a plot.\n"))
;; Display layout information
(alert msg)
;; Toggle object hidden state for Layout1
(vla-put-PlotHidden (vla-item Layouts "Layout1") (if (= (vla-get-PlotHidden (vla-item Layouts "Layout1")) :vlax-true) :vlax-false :vlax-true))
;; Display new hidden information
(setq msg "")
(alert msg)
GMT+8, 2026-10-27 05:16
