Plot 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 608| 评论: 0|原作者: admin|来自: AutoCAD
Plot 属性 (ActiveX)
获取文档的 Plot 对象。
object.Plot
类别: 文档
此属性应用于的对象。
只读:是的
类型: 剧情
文档的 Plot 对象。
Sub Example_Plot()
    ' This example sends a plot of the current drawing
    ' to a file.
    ThisDrawing.ActiveLayout.ConfigName = "DWF6 ePlot.pc3"
    ' Define the plot variable
    Dim currentPlot As AcadPlot
    Set currentPlot = ThisDrawing.Plot
    ' Define the output file name.
    ' Use "" to use the drawing name as the file name.
    ' Note: if the file name exists an error will be generated.
    Dim plotFileName As String
    plotFileName = "MyPlot"
    currentPlot.PlotToFile plotFileName
(defun c:Example_Plot()
    ;; This example sends a plot of the current drawing
    ;; to a file.
    ;; Set a device current that outputs to a file
    (vla-put-ConfigName (vla-get-ActiveLayout doc) "DWF6 ePlot.pc3")
    ;; Define the plot variable
    (setq currentPlot (vla-get-Plot doc))
    ;; Define the output file name.
    ;; Use "" to use the drawing name as the file name.
    ;; Note: if the file name exists an error will be generated.
    (setq plotFileName "MyPlot")
    (vla-PlotToFile currentPlot plotFileName)
GMT+8, 2026-10-27 04:59
