PickGroup 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 757| 评论: 0|原作者: admin|来自: AutoCAD
确定选取组中的单个对象是否选择整个组。
object.PickGroup
类型:首选项选择
此属性应用于的对象。
只读:不
类型:布尔
  • True:选取组中的一个对象会导致整个组被选中。
  • False:选取组中的一个对象会导致仅选中该对象。
此属性的初始值为 。False
Sub Example_PickGroup()
    ' This example reads and modifies the preference value that
    ' determines if picking a single object in a group selects the entire group.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSelection
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Selection
    originalValue = ACADPref.PickGroup
    MsgBox "The PickGroup preference is set to: " & originalValue
    ' Modify the PickGroup preference by toggling the value
    ACADPref.PickGroup = Not (ACADPref.PickGroup)
    newValue = ACADPref.PickGroup
    MsgBox "The PickGroup preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.PickGroup = originalValue
    MsgBox "The PickGroup preference was reset back to: " & originalValue
(defun c:Example_PickGroup()
    ;; This example reads and modifies the preference value that
    ;; determines if picking a single object in a group selects the entire group.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-PickGroup (vla-get-Selection preferences)))
    (alert (strcat "The PickGroup preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the PickGroup preference by toggling the value
    (vla-put-PickGroup (vla-get-Selection preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-PickGroup (vla-get-Selection preferences)))
    (alert (strcat "The PickGroup preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-PickGroup (vla-get-Selection preferences) originalValue)
    (alert (strcat "The PickGroup preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-26 23:53
