PickfirstSelectionSet 属性 (ActiveX)
获取 pickfirst 选择集。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_PickfirstSelectionSet()
' This example lists all the objects in the pickfirst selection set.
' Before running this example, create some objects in the active
' drawing and select those objects. The objects currently selected
' in the active drawing will be returned in the pickfirst selection set.
Dim pfSS As AcadSelectionSet
Dim ssobject As AcadEntity
Dim msg As String
msg = ""
Set pfSS = ThisDrawing.PickfirstSelectionSet
For Each ssobject In pfSS
msg = msg & vbCrLf & ssobject.ObjectName
Next ssobject
MsgBox "The Pickfirst selection set contains: " & msg
可视化 LISP: (vl-load-com)
(defun c:Example_PickfirstSelectionSet()
;; This example lists all the objects in the pickfirst selection set.
;; Before running this example, create some objects in the active
;; drawing and select those objects. The objects currently selected
;; in the active drawing will be returned in the pickfirst selection set.
(setq msg ""
pfSS (vla-get-PickfirstSelectionSet doc))
(vlax-for ssobject pfSS
(setq msg (strcat msg "\n" (vla-get-ObjectName ssobject)))
(alert (strcat "The Pickfirst selection set contains: " msg))
GMT+8, 2026-10-28 04:54
