PickBoxSize 属性 (ActiveX)
指定对象选择目标的大小。 支持的平台:仅限 Windows 属性值只读:不 类型:长 对象选择目标的高度(以像素为单位)。您可以输入一个介于 0 到 50 之间的值。 言论此属性的初始值为 3。 注意:此属性的值存储在 PICKBOX 系统变量中。
例子VBA: Sub Example_PickBoxSize()
' This example reads and modifies the preference value that controls
' the size of the object selection target.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSelection
' Get the selection preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Selection
originalValue = ACADPref.PickBoxSize
MsgBox "The PickBoxSize preference is set to: " & originalValue
' Modify the PickBoxSize preference by setting it to 5
ACADPref.PickBoxSize = 5
newValue = ACADPref.PickBoxSize
MsgBox "The PickBoxSize preference has been set to: " & newValue
' this preference in effect
ACADPref.PickBoxSize = originalValue
MsgBox "The PickBoxSize preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_PickBoxSize()
;; This example reads and modifies the preference value that controls
;; the size of the object selection target.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-PickBoxSize (vla-get-Selection preferences)))
(alert (strcat "The PickBoxSize preference is set to: " (itoa originalValue)))
;; Modify the PickBoxSize preference by setting it to 5
(vla-put-PickBoxSize (vla-get-Selection preferences) 5)
(setq newValue (vla-get-PickBoxSize (vla-get-Selection preferences)))
(alert (strcat "The PickBoxSize preference has been set to: " (itoa newValue)))
;; this preference in effect
(vla-put-PickBoxSize (vla-get-Selection preferences) originalValue)
(alert (strcat "The PickBoxSize preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-27 05:43
