Perimeter 属性 (ActiveX)
获取内部和外部区域循环的总长度。 支持的平台:仅限 Windows 属性值只读:是的 类型:双 周长以绘图单位返回。 言论没有其他评论。 例子VBA: Sub Example_Perimeter()
' This example creates a region from an arc and a line.
' It then returns the length of the perimeter of the region.
Dim curves(0 To 1) As AcadEntity
Dim arcObj As AcadArc
Dim lineObj As AcadLine
' Create the arc and line
Dim radius As Double
Dim startAngle As Double
Dim endAngle As Double
centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0#
radius = 2#
startAngle = 0
endAngle = 3.141592
Set arcObj = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle)
Set lineObj = ThisDrawing.ModelSpace.AddLine(arcObj.startPoint, arcObj.endPoint)
Set curves(0) = arcObj
Set curves(1) = lineObj
' Create the region
Dim regionObj As Variant
regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
ZoomAll
' Find the perimeter of the region.
Dim perimeter As Double
perimeter = regionObj(0).perimeter
MsgBox "The perimeter of the region is " & regionObj(0).perimeter, , "Perimeter Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Perimeter()
;; This example creates a region from an arc and a line.
;; It then returns the length of the perimeter of the region.
;; Create the arc and line
(setq centerPoint (vlax-3d-point 5 3 0)
radius 2
startAngle 0
endAngle 3.141592)
(setq arcObj (vla-AddArc modelSpace centerPoint radius startAngle endAngle))
(setq lineObj (vla-AddLine modelSpace (vla-get-StartPoint arcObj) (vla-get-EndPoint arcObj)))
(setq curves (vlax-make-safearray vlax-vbObject '(0 . 1)))
(vlax-safearray-put-element curves 0 arcObj)
(vlax-safearray-put-element curves 1 lineObj)
;; Create the region
(setq regionObj (vla-AddRegion modelSpace curves))
(vla-ZoomAll acadObj)
;; Find the perimeter of the region.
(setq perimeter (vla-get-Perimeter (vlax-safearray-get-element (vlax-variant-value regionObj) 0)))
(alert (strcat "The perimeter of the region is " (rtos perimeter 2)))
GMT+8, 2026-10-28 04:49
