PatternType 属性 (ActiveX)
获取用于填充的模式类型。 支持的平台:仅限 Windows 属性值只读:是的 类型:枚举acPatternType
言论图案填充的图案类型只能通过图案填充创建方法或方法进行设置。AddHatchSetPattern 例子VBA: Sub Example_PatternType()
' This example creates an associative hatch in model space.
' The type of the hatch pattern is then returned.
Dim hatchObj As AcadHatch
Dim patternName As String
Dim PatternType As Long
Dim bAssociativity As Boolean
' Define the hatch
patternName = "ANSI31"
PatternType = acHatchPatternTypePreDefined
bAssociativity = True
' Create the associative Hatch object
Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
' Create the outer loop for the hatch.
' An arc and a line are used to create a closed loop.
Dim outerLoop(0 To 1) As AcadEntity
Dim center(0 To 2) As Double
Dim radius As Double
Dim startAngle As Double
Dim endAngle As Double
center(0) = 5: center(1) = 3: center(2) = 0
radius = 3
startAngle = 0
endAngle = 3.141592
Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle)
Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint)
' Append the outer loop to the hatch object
hatchObj.AppendOuterLoop (outerLoop)
' Append the first circle as one inner loop
Dim innerLoop1(0) As AcadEntity
center(0) = 5: center(1) = 4.5: center(2) = 0
radius = 1
Set innerLoop1(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
hatchObj.AppendInnerLoop (innerLoop1)
' Append the second circle as the other inner loop
Dim innerLoop2(0) As AcadEntity
radius = 0.5
Set innerLoop2(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
hatchObj.AppendInnerLoop (innerLoop2)
' Evaluate and display the hatch
hatchObj.Evaluate
ThisDrawing.Regen True
' Find the type of hatch
PatternType = hatchObj.PatternType
MsgBox "The type of hatch pattern is " & Choose(hatchObj.PatternType + 1, "acHatchPatternTypeUserDefined", "acHatchPatternTypePreDefined", "acHatchPatternTypeCustomDefined"), , "PatternType Example"
可视化 LISP: (vl-load-com)
(defun c:Example_PatternType()
;; This example creates an associative hatch in model space.
;; The type of the hatch pattern is then returned.
;; Define the hatch
(setq patternName "ANSI31"
patternType acHatchPatternTypePreDefined
bAssociativity :vlax-true)
;; Create the associative Hatch object
(setq hatchObj (vla-AddHatch modelSpace patternType patternName bAssociativity acHatchObject))
;; Create the outer loop for the hatch.
;; An arc and a line are used to create a closed loop.
(setq center (vlax-3d-point 5 3 0)
radius 3
startAngle 0
endAngle 3.141592)
(setq arc (vla-AddArc modelSpace center radius startAngle endAngle))
(setq line (vla-AddLine modelSpace (vla-get-StartPoint arc) (vla-get-EndPoint arc)))
(setq outerLoop (vlax-make-safearray vlax-vbObject '(0 . 1)))
(vlax-safearray-put-element outerLoop 0 arc)
(vlax-safearray-put-element outerLoop 1 line)
;; Append the outer loop to the hatch object
(vla-AppendOuterLoop hatchObj outerLoop)
;; Append the first circle as one inner loop
(setq center (vlax-3d-point 5 4.5 0)
radius 1)
(setq circle1 (vla-AddCircle modelSpace center radius))
(setq innerLoop1 (vlax-make-safearray vlax-vbObject '(0 . 0)))
(vlax-safearray-put-element innerLoop1 0 circle1)
(vla-AppendInnerLoop hatchObj innerLoop1)
;; Append the second circle as the other inner loop
(setq radius 0.5)
(setq innerLoop2 (vlax-make-safearray vlax-vbObject '(0 . 0)))
(setq circle2 (vla-AddCircle modelSpace center radius))
(vlax-safearray-put-element innerLoop2 0 circle2)
(vla-AppendInnerLoop hatchObj innerLoop2)
;; Evaluate and display the hatch
(vla-Evaluate hatchObj)
(vla-Regen doc :vlax-true)
;; Find the type of hatch
(setq patternType (vla-get-PatternType hatchObj))
(alert (strcat "The type of hatch pattern is " (cond
((= patternType acHatchPatternTypeUserDefined) "acHatchPatternTypeUserDefined")
((= patternType acHatchPatternTypePreDefined) "acHatchPatternTypePreDefined")
((= patternType acHatchPatternTypeCustomDefined) "acHatchPatternTypeCustomDefined")
GMT+8, 2026-10-28 07:34
