Parent 属性 (ActiveX)
获取对象的父级。 支持的平台:仅限 Windows 签名VBA: object.Parent
属性值只读:是/否 类型:对象 用户指定的变量必须声明为适当的对象类型。有效的对象类型包括:Application、MenuBar、MenuGroup、MenuGroups、PopupMenu、PopupMenus、Toolbar、Toolbars 言论没有其他评论。 例子VBA: Sub Example_Parent()
' This example creates a new toolbar and then finds the parent toolbar.
' To remove the toolbar after execution of this macro, use the Customize Menu
' option from the Tools menu.
Dim currMenuGroup As acadMenuGroup
Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
' Create the new toolbar
Dim newToolBar As AcadToolbar
Set newToolBar = currMenuGroup.Toolbars.Add("MyTools")
' Add a button to the new toolbar.
' All three buttons will have the same macro attached.
Dim newButton1 As AcadToolbarItem
Dim openMacro As String
' Assign the macro string the VB equivalent of "ESC ESC _open "
openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
Set newButton1 = newToolBar.AddToolbarButton("", "OpenFile", "Open a file.", openMacro)
' Display the toolbar
newToolBar.Visible = True
' Find the parent toolbar for the toolbar button
MsgBox "The " & newButton1.name & " button is on the " & newButton1.Parent.name & " toolbar."
可视化 LISP: (vl-load-com)
(defun c:Example_Parent()
;; This example creates a new toolbar and then finds the parent toolbar.
;; To remove the toolbar after execution of this macro, use the Customize Menu
;; option from the Tools menu.
(setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
;; Create the new toolbar
(setq newToolBar (vla-Add (vla-get-Toolbars currMenuGroup) "MyTools"))
;; Add a button to the new toolbar.
;; All three buttons will have the same macro attached.
;; Assign the macro string the VB equivalent of "ESC ESC _open "
(setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
(setq newButton1 (vla-AddToolbarButton newToolBar "" "OpenFile" "Open a file." openMacro))
;; Display the toolbar
(vla-put-Visible newToolBar :vlax-true)
;; Find the parent toolbar for the toolbar button
(alert (strcat "The " (vla-get-Name newButton1) " button is on the " (vla-get-Name (vla-get-Parent newButton1)) " toolbar."))
GMT+8, 2026-10-28 17:17
