OrthoOn 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 865| 评论: 0|原作者: admin|来自: AutoCAD
指定视口的“等轴测捕捉”模式的状态。
object.OrthoOn
类型:视口
此属性应用于的对象。
只读:不
类型:布尔
  • True:等距捕捉模式已打开。
  • False:等距捕捉模式已关闭。
Sub Example_OrthoOn()
    ' This example toggles the setting of OrthoOn.
    Dim viewportObj As AcadViewport
    ' Set the viewportObj variable to the activeviewport
    Set viewportObj = ThisDrawing.ActiveViewport
    ' Display the current setting of OrthoOn
    MsgBox "Isometric snap mode is: " & IIf(viewportObj.OrthoOn, "On", "Off"), , "OrthoOn Example"
    ' Toggle the setting of OrthoOn
    viewportObj.OrthoOn = Not (viewportObj.OrthoOn)
    ' Reset the active viewport to see the change on the AutoCAD status bar
    ThisDrawing.ActiveViewport = viewportObj
    MsgBox "Isometric snap mode is now: " & IIf(viewportObj.OrthoOn, "On", "Off"), , "OrthoOn Example"
(defun c:Example_OrthoOn()
    ;; This example toggles the setting of OrthoOn.
    ;; Set the viewportObj variable to the activeviewport
    (setq viewportObj (vla-get-ActiveViewport doc))
    ;; Display the current setting of OrthoOn
    (alert (strcat "Isometric snap mode is: " (if (= (vla-get-OrthoOn viewportObj) :vlax-true) "On" "Off")))
    ;; Toggle the setting of OrthoOn
    (vla-put-OrthoOn viewportObj (if (= (vla-get-OrthoOn viewportObj) :vlax-true) :vlax-false :vlax-true))
    ;; Reset the active viewport to see the change on the AutoCAD status bar
    (vla-put-ActiveViewport doc viewportObj)
    (alert (strcat "Isometric snap mode is now: " (if (= (vla-get-OrthoOn viewportObj) :vlax-true) "On" "Off")))
GMT+8, 2026-10-27 04:54
