Origin 属性 (ActiveX)
指定 WCS 坐标中 UCS、块、剖面线或栅格影像的原点。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双元素或三元素的双精度数组) 2D 点:表示相对于媒体左下角的原点的 X 和 Y 值。 3D 点:指定对象原点的 3D WCS 坐标。 言论填充:此属性是填充图元模式的原点坐标。 例子VBA: Sub Example_Origin()
' This example creates a UCS and returns its origin.
Dim viewportObj As AcadViewport
' Set the viewportObj variable to the activeviewport
Set viewportObj = ThisDrawing.ActiveViewport
' Create a new UCS with origin 2, 2, 0
Dim ucsObj As AcadUCS
Dim origin(0 To 2) As Double
Dim xAxisPoint(0 To 2) As Double
Dim yAxisPoint(0 To 2) As Double
origin(0) = 2: origin(1) = 2: origin(2) = 0
xAxisPoint(0) = 3: xAxisPoint(1) = 2: xAxisPoint(2) = 0
yAxisPoint(0) = 2: yAxisPoint(1) = 3: yAxisPoint(2) = 0
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
ThisDrawing.ActiveUCS = ucsObj
viewportObj.UCSIconOn = True
viewportObj.UCSIconAtOrigin = True
ThisDrawing.ActiveViewport = viewportObj
' Display the current origin for the new UCS
MsgBox "The origin of the UCS is: " & ucsObj.origin(0) & ", " & ucsObj.origin(1) & ", " & ucsObj.origin(2), , "Origin Example"
' Change the origin of the UCS
origin(0) = 4: origin(1) = 4: origin(2) = 0
ucsObj.origin = origin
' Reset the active UCS and viewport to see the change
MsgBox "The origin of the UCS is now: " & ucsObj.origin(0) & ", " & ucsObj.origin(1) & ", " & ucsObj.origin(2), , "Origin Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Origin()
;; This example creates a UCS and returns its origin.
;; Set the viewportObj variable to the activeviewport
(setq viewportObj (vla-get-ActiveViewport doc))
;; Create a new UCS with origin 2, 2, 0
(setq origin (vlax-3d-point 2 2 0)
xAxisPoint (vlax-3d-point 3 2 0)
yAxisPoint (vlax-3d-point 2 3 0))
(setq ucsObj (vla-Add (vla-get-UserCoordinateSystems doc) origin xAxisPoint yAxisPoint "UCS1"))
(vla-put-ActiveUCS doc ucsObj)
(vla-put-UCSIconOn viewportObj :vlax-true)
(vla-put-UCSIconAtOrigin viewportObj :vlax-true)
(vla-put-ActiveViewport doc viewportObj)
;; Display the current origin for the new UCS
(alert (strcat "The origin of the UCS is: " (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin ucsObj)) 0) 2) ", "
(rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin ucsObj)) 1) 2) ", "
(rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin ucsObj)) 2) 2)))
;; Change the origin of the UCS
(setq origin (vlax-3d-point 4 4 0))
(vla-put-Origin ucsObj origin)
;; Reset the active UCS and viewport to see the change
(alert (strcat "The origin of the UCS is now: " (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin ucsObj)) 0) 2) ", "
GMT+8, 2026-10-27 01:19
