OpenSave 属性 (ActiveX)
获取 PreferencesOpenSave 对象。 支持的平台:仅限 Windows 言论该对象保存存储在注册表中的“选项”对话框的“打开和保存”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesOpenSaveDatabasePreferences 例子VBA: Sub Example_OpenSave()
' This example obtains a reference to the OpenSave Preferences object
' from the Application Preferences object, and reads one of the OpenSave
' preferences
Dim ACADPref As AcadPreferencesOpenSave
' Obtain a reference to the OpenSave Preferences object
Set ACADPref = ThisDrawing.Application.preferences.OpenSave
MsgBox "You now have access to the properties and methods of the OpenSave Preferences object!"
MsgBox "The OpenSave preference TempFileExtension is set to: " & ACADPref.TempFileExtension
可视化 LISP: Not available |
GMT+8, 2026-10-27 00:38
