ObjectSortByRegens 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 872| 评论: 0|原作者: admin|来自: AutoCAD
按再生顺序切换图形对象的排序。
object.ObjectSortByRegens
类型:DatabasePreferences
此属性应用于的对象。
只读:不
类型:布尔
  • True:启用按再生顺序排序。
  • False:禁用按再生顺序排序。
此属性的初始值为 。False
AutoCAD 最初仅允许对打印和 PostScript 输出进行排序。设置其他排序选项可能会导致再生和重绘时间变慢。
注意:此属性的值存储在 SORTENTS 系统变量中。
Sub Example_ObjectSortByRegens()
    ' This example reads and modifies the preference value that controls
    ' the sorting of drawing objects by regeneration order.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadDatabasePreferences
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.preferences
    originalValue = ACADPref.ObjectSortByRegens
    MsgBox "The ObjectSortByRegens preference is set to: " & originalValue
    ' Modify the ObjectSortByRegens preference by toggling the value
    ACADPref.ObjectSortByRegens = Not (ACADPref.ObjectSortByRegens)
    newValue = ACADPref.ObjectSortByRegens
    MsgBox "The ObjectSortByRegens preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.ObjectSortByRegens = originalValue
    MsgBox "The ObjectSortByRegens preference was reset back to: " & originalValue
(defun c:Example_ObjectSortByRegens()
    ;; This example reads and modifies the preference value that controls
    ;; the sorting of drawing objects by regeneration order.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq preferences (vla-get-Preferences doc))
    (setq originalValue (vla-get-ObjectSortByRegens preferences))
    (alert (strcat "The ObjectSortByRegens preference is set to: " (if (= originalValue :vlax-true) "True"  "False")))
    ;; Modify the ObjectSortByRegens preference by toggling the value
    (vla-put-ObjectSortByRegens preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-ObjectSortByRegens preferences))
    (alert (strcat "The ObjectSortByRegens preference has been set to: " (if (= newValue :vlax-true) "True"  "False")))
    ;;         this preference in effect
    (vla-put-ObjectSortByRegens preferences originalValue)
    (alert (strcat "The ObjectSortByRegens preference was reset back to: " (if (= originalValue :vlax-true) "True"  "False")))
GMT+8, 2026-10-27 04:48
