ObjectSortByRedraws 属性 (ActiveX)
按重绘顺序切换绘图对象的排序。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False AutoCAD 最初仅允许对打印和 PostScript 输出进行排序。设置其他排序选项可能会导致再生和重绘时间变慢。 注意:此属性的值存储在 SORTENTS 系统变量中。
例子VBA: Sub Example_ObjectSortByRedraws()
' This example reads and modifies the preference value that controls
' the sorting of drawing objects by redraw order.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadDatabasePreferences
' Get the user preferences object
Set ACADPref = ThisDrawing.preferences
originalValue = ACADPref.ObjectSortByRedraws
MsgBox "The ObjectSortByRedraws preference is set to: " & originalValue
' Modify the ObjectSortByRedraws preference by toggling the value
ACADPref.ObjectSortByRedraws = Not (ACADPref.ObjectSortByRedraws)
newValue = ACADPref.ObjectSortByRedraws
MsgBox "The ObjectSortByRedraws preference has been set to: " & newValue
' this preference in effect
ACADPref.ObjectSortByRedraws = originalValue
MsgBox "The ObjectSortByRedraws preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_ObjectSortByRedraws()
;; This example reads and modifies the preference value that controls
;; the sorting of drawing objects by redraw order.
;; When finished, this example resets the preference value back to
;; its original value.
(setq preferences (vla-get-Preferences doc))
(setq originalValue (vla-get-ObjectSortByRedraws preferences))
(alert (strcat "The ObjectSortByRedraws preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the ObjectSortByRedraws preference by toggling the value
(vla-put-ObjectSortByRedraws preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-ObjectSortByRedraws preferences))
(alert (strcat "The ObjectSortByRedraws preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-ObjectSortByRedraws preferences originalValue)
(alert (strcat "The ObjectSortByRedraws preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 05:00
