NumberOfFaces 属性 (ActiveX)
获取 PolyfaceMesh 的人脸数。 支持的平台:仅限 Windows 属性值只读:是的 类型:长 的面数。PolyfaceMesh 言论没有其他评论。 例子VBA: Sub Example_NumberOfFaces()
' This example creates a PolyFaceMesh and displays the number of faces it contains
Dim vertexList(0 To 17) As Double
Dim FaceList(0 To 7) As Integer
Dim NewPolyFaceMeshObj As AcadPolyfaceMesh
Dim direction(0 To 2) As Double
'Data for new PolyFaceMesh object
vertexList(0) = 4: vertexList(1) = 7: vertexList(2) = 0
vertexList(3) = 5: vertexList(4) = 7: vertexList(5) = 0
vertexList(6) = 6: vertexList(7) = 7: vertexList(8) = 0
vertexList(9) = 4: vertexList(10) = 6: vertexList(11) = 0
vertexList(12) = 5: vertexList(13) = 6: vertexList(14) = 0
vertexList(15) = 6: vertexList(16) = 6: vertexList(17) = 6
FaceList(0) = 1: FaceList(1) = 2: FaceList(2) = 5
FaceList(3) = 4: FaceList(4) = 2: FaceList(5) = 3
FaceList(6) = 6: FaceList(7) = 5
' Create new PolyFaceMesh object
Set NewPolyFaceMeshObj = ModelSpace.AddPolyfaceMesh(vertexList, FaceList)
NewPolyFaceMeshObj.Update
' Change the viewing direction of the viewport to
' better see the polyface mesh
direction(0) = -1: direction(1) = -1: direction(2) = 1
ThisDrawing.ActiveViewport.direction = direction
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
' Display number of faces in this PolyFaceMesh
MsgBox "The new PolyFaceMesh contains " & NewPolyFaceMeshObj.NumberOfFaces & " faces."
可视化 LISP: (vl-load-com)
(defun c:Example_NumberOfFaces()
;; This example creates a PolyFaceMesh and displays the number of faces it contains
;; Data for new PolyFaceMesh object
(setq vertexList (vlax-make-safearray vlax-vbDouble '(0 . 17)))
(vlax-safearray-fill vertexList '(4 7 0
5 7 0
6 7 0
4 6 0
5 6 0
6 6 6
(setq FaceList (vlax-make-safearray vlax-vbInteger '(0 . 7)))
(vlax-safearray-fill FaceList '(1
2
5
4
2
3
6
5
;; Create new PolyFaceMesh object
(setq NewPolyFaceMeshObj (vla-AddPolyfaceMesh modelSpace vertexList FaceList))
(vla-Update NewPolyFaceMeshObj)
;; Change the viewing direction of the viewport to
;; better see the polyface mesh
(setq direction (vlax-3d-point -1 -1 1))
(setq activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport direction)
(vla-put-ActiveViewport doc activeViewport)
(vla-ZoomAll acadObj)
;; Display number of faces in this PolyFaceMesh
(alert (strcat "The new PolyFaceMesh contains " (itoa (vla-get-NumberOfFaces NewPolyFaceMeshObj)) " faces."))
GMT+8, 2026-10-27 03:14
