NumberOfCopies 属性 (ActiveX)
指定要打印的副本数。 支持的平台:仅限 Windows 属性值只读:不 类型:长 要打印的副本数。 言论没有其他评论。 例子VBA: Sub Example_NumberOfCopies()
' This example plots the layouts of a drawing.
Dim oPlot As AcadPlot
Dim AddedLayouts() As String
Dim LayoutList As Variant
Dim oLayout As AcadLayout
Dim ArraySize As Integer, BatchCount As Integer
For Each oLayout In ThisDrawing.Layouts
ArraySize = ArraySize + 1
ReDim Preserve AddedLayouts(1 To ArraySize)
AddedLayouts(ArraySize) = oLayout.Name
Next
LayoutList = AddedLayouts
Set oPlot = ThisDrawing.Plot
oPlot.SetLayoutsToPlot LayoutList
oPlot.PlotToDevice "DWF6 ePlot.pc3"
可视化 LISP: (vl-load-com)
(defun c:Example_NumberOfCopies()
;; This example plots the layouts of a drawing.
(setq AddedLayouts (vlax-make-safearray vlax-vbString (cons 0 (1- (vla-get-Count (vla-get-Layouts doc)))))
ArraySize 0)
(vlax-for oLayout (vla-get-Layouts doc)
(vlax-safearray-put-element AddedLayouts ArraySize (vla-get-Name oLayout))
(setq ArraySize (1+ ArraySize))
(setq oPlot (vla-get-Plot doc))
(vla-SetLayoutsToPlot oPlot AddedLayouts)
(vla-PlotToDevice oPlot "DWF6 ePlot.pc3")
GMT+8, 2026-10-27 19:20
