NumberOfControlPoints 属性 (ActiveX)
获取样条的控制点数。 支持的平台:仅限 Windows 属性值只读:是的 类型:整数 样条的控制点数。 言论控制点通过向样条曲线的一部分添加权重来微调样条定义。 您可以使用该方法查询控制点的当前位置。您可以使用该方法为控制点设置新的坐标位置。您可以使用该方法为控制点设置新权重。GetControlPointSetControlPointSetWeight 例子VBA: Sub Example_NumberOfControlPoints()
' This example creates a spline object in model space.
' It then finds the number of control points for that spline.
' Create the spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
MsgBox "The Spline has " & splineObj.NumberOfControlPoints & " control points.", , "NumberOfControlPoints Example"
可视化 LISP: (vl-load-com)
(defun c:Example_NumberOfControlPoints()
;; This example creates a spline object in model space.
;; It then finds the number of control points for that spline.
;; Create the spline
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(1 1 0
5 5 0
10 0 0
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
(alert (strcat "The Spline has " (itoa (vla-get-NumberOfControlPoints splineObj)) " control points."))
GMT+8, 2026-10-27 05:44
