MTextAttribute 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 864| 评论: 0|原作者: admin|来自: AutoCAD
确定属性是否为多行。
object.MTextAttribute
类型:Attribute、AttributeReference
此方法应用到的对象。
只读:不
类型:布尔
  • True:属性为多行。
  • False:属性为单行。
Sub Example_AddAttribute()
    ' This example creates an attribute definition in model space.
    Dim attributeObj As AcadAttribute
    Dim height As Double
    Dim mode As Long
    Dim prompt As String
    Dim tag As String
    Dim value As String
    ' Define the attribute definition
    height = 1#
    mode = acAttributeModeVerify
    prompt = "New Prompt"
    insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0
    tag = "NEW_TAG"
    value = "New Value"
    ' Create the attribute definition object in model space
    Set attributeObj = ThisDrawing.ModelSpace.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
    ZoomAll
(defun c:Example_AddAttribute()
    ;; This example creates an attribute definition in model space.
    ;; Define the attribute definition
    (setq insertionPoint (vlax-3d-point 5 5 0)
          attHeight 1
          attMode acAttributeModeVerify
          attPrompt "New Prompt"
          attTag "NEW_TAG"
          attValue "New Value")
    ;; Create the attribute definition object in model space
    (setq attributeObj (vla-AddAttribute modelSpace attHeight attMode attPrompt insertionPoint attTag attValue))
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-27 13:08
