MRUNumber 属性 (ActiveX)
指定“文件”菜单中显示的最近使用的文件数。 支持的平台:仅限 Windows 属性值只读:是的 类型:长 “文件”菜单中显示的最近使用的文件数。 言论此属性的默认值为 4。 例子VBA: Sub Example_MRUNumber()
' This example reads the preference value containing
' the number of most recently used files that are shown in the File menu.
Dim ACADPref As AcadPreferencesOpenSave
Dim originalValue As Variant
' Get the OpenSave preferences object
Set ACADPref = ThisDrawing.Application.preferences.OpenSave
' Read and display the preference value
originalValue = ACADPref.MRUNumber
MsgBox "The number of most recently used files that are shown is: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_MRUNumber()
;; This example reads the preference value containing
;; the number of most recently used files that are shown in the File menu.
;; Get the OpenSave preferences object
(setq ACADPref (vla-get-OpenSave preferences))
;; Read and display the preference value
(setq originalValue (vla-get-MRUNumber ACADPref))
(alert (strcat "The number of most recently used files that are shown is: " (itoa originalValue)))
GMT+8, 2026-10-27 05:20
