ModelType 属性 (ActiveX)
指定打印配置是应用于模型空间还是所有布局。 支持的平台:仅限 Windows 属性值只读:是的 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_ModelType()
' This example creates a plot configuration object
' and then finds the ModelType for the object.
Dim PlotConfigObj As AcadPlotConfiguration
' Creates the MText Object
Set PlotConfigObj = ThisDrawing.PlotConfigurations.Add("NewPlotConfiguration")
' Find the current ModelType
Dim currModelType As Boolean
currModelType = PlotConfigObj.ModelType
MsgBox "The ModelType for the object is: " & currModelType
可视化 LISP: (vl-load-com)
(defun c:Example_ModelType()
;; This example creates a plot configuration object
;; and then finds the ModelType for the object.
;; Creates the MText Object
(setq PlotConfigObj (vla-Add (vla-get-PlotConfigurations doc) "NewPlotConfiguration"))
;; Find the current ModelType
(setq currModelType (vla-get-ModelType PlotConfigObj))
(alert (strcat "The ModelType for the object is: " (if (= currModelType :vlax-true) "True" "False")))
GMT+8, 2026-10-27 11:11
