MenuBar 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 653| 评论: 0|原作者: admin|来自: AutoCAD
获取会话的 MenuBar 对象。
object.MenuBar
类型: 应用
此属性应用于的对象。
只读:是的
类型:MenuBar
会话的对象。MenuBar
Sub Example_MenuBar()
    ' This example uses MenuBar to obtain a reference to the AutoCAD File menu.
    ' It then creates a new menu item and inserts it at the bottom of the File menu.
    ' The menu item will be automatically removed when AutoCAD is restarted
    Dim menu As AcadPopupMenu, newMenuItem As AcadPopupMenuItem
    Dim openMacro As String
    On Error GoTo ERRORTRAP
    ' Use MenuBar property to obtain reference to the AutoCAD File menu
    Set menu = ThisDrawing.Application.MenuBar.Item("&File")
    ' Add a menu item to the new menu and
    ' assign an Open macro (VBA equivalent of: "ESC ESC _open ")
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    ' Add a menu separator
    menu.AddSeparator (menu.count + 1)
    ' Add new menu item to File menu
    Set newMenuItem = menu.AddMenuItem(menu.count + 1, "NEW MENU ITEM", openMacro)
    MsgBox "A new menu item has been added to the File menu!"
    Exit Sub
ERRORTRAP:
    MsgBox "The following error has occurred: " & Err.Description
(defun c:Example_MenuBar()
    ;; This example uses MenuBar to obtain a reference to the AutoCAD File menu.
    ;; It then creates a new menu item and inserts it at the bottom of the File menu.
    ;; The menu item will be automatically removed when AutoCAD is restarted
    ;; Use MenuBar property to obtain reference to the AutoCAD File menu
    (setq menu (vla-Item (vla-get-MenuBar acadObj) "&File"))
    ;; Add a menu item to the new menu and
    ;; assign an Open macro (VBA equivalent of: "ESC ESC _open ")
    (setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
    ;; Add a menu separator
    (vla-AddSeparator menu (1+ (vla-get-Count menu)))
    ;; Add new menu item to File menu
    (setq newMenuItem (vla-AddMenuItem menu (1+ (vla-get-Count menu)) "Open File" openMacro))
    (alert "A new menu item has been added to the File menu!")
GMT+8, 2026-10-27 13:08
