MaxAutoCADWindow 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 970| 评论: 0|原作者: admin|来自: AutoCAD
指定启动时 AutoCAD 窗口是否应填充整个屏幕区域。
object.MaxAutoCADWindow
类型:首选项显示
此属性应用于的对象。
只读:不
类型:布尔
  • True:最大化 AutoCAD。
  • False:不最大化 AutoCAD。
Sub Example_MaxAutoCADWindow()
    ' MaxAutoCADWindow. It then changes the value, and finally
    Dim currMaxAutoCADWindow As Boolean
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current MaxAutoCADWindow value
    currMaxAutoCADWindow = preferences.DISPLAY.MaxAutoCADWindow
    MsgBox "The current value for MaxAutoCADWindow is " & preferences.DISPLAY.MaxAutoCADWindow, vbInformation, "MaxAutoCADWindow Example"
    ' Change the value for MaxAutoCADWindow
    preferences.DISPLAY.MaxAutoCADWindow = Not (currMaxAutoCADWindow)
    MsgBox "The new value for MaxAutoCADWindow is " & preferences.DISPLAY.MaxAutoCADWindow, vbInformation, "MaxAutoCADWindow Example"
    ' Reset MaxAutoCADWindow to its original value
    preferences.DISPLAY.MaxAutoCADWindow = currMaxAutoCADWindow
    MsgBox "The MaxAutoCADWindow value is reset to " & preferences.DISPLAY.MaxAutoCADWindow, vbInformation, "MaxAutoCADWindow Example"
(defun c:Example_MaxAutoCADWindow()
    ;; MaxAutoCADWindow. It then changes the value, and finally
    ;; Retrieve the current MaxAutoCADWindow value
    (setq currMaxAutoCADWindow (vla-get-MaxAutoCADWindow (vla-get-Display preferences)))
    (alert (strcat "The current value for MaxAutoCADWindow is " (if (= currMaxAutoCADWindow :vlax-true) "True"  "False")))
    ;; Change the value for MaxAutoCADWindow
    (vla-put-MaxAutoCADWindow (vla-get-Display preferences) (if (= currMaxAutoCADWindow :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The new value for MaxAutoCADWindow is " (if (= (vla-get-MaxAutoCADWindow (vla-get-Display preferences)) :vlax-true) "True" "False")))
    ;; Reset MaxAutoCADWindow to its original value
    (vla-put-MaxAutoCADWindow (vla-get-Display preferences) currMaxAutoCADWindow)
    (alert (strcat "The MaxAutoCADWindow value is reset to " (if (= (vla-get-MaxAutoCADWindow (vla-get-Display preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-27 05:13
