Material 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 752| 评论: 0|原作者: admin|来自: AutoCAD
指定材料的名称。
object.Material
类型:所有图形对象、AttributeReference、Group、Layer、SubDMeshFace、SubEntSolidFace
此属性应用于的对象。
只读:不
类型:字符串
材料的名称。
Sub Example_AddMaterial()
    Dim oMaterial As AcadMaterial
    Dim oMaterials As AcadMaterials
    Set oMaterial = ThisDrawing.Materials.Add("TestMaterial")
    oMaterial.Description = "This material demonstrates how to add a material to a database."
    ThisDrawing.ActiveMaterial = oMaterial
    ' Display the name and description of the layer
    MsgBox oMaterial.Name & " has been added." & vbCrLf & _
            "Name: " & vbCrLf & oMaterial.Name & vbCrLf & vbCrLf & _
            "Description: " & vbCrLf & _
(defun c:Example_Materials()
    (setq oMaterial (vla-Add (vla-get-Materials doc) "TestMaterial"))
    (vla-put-Description oMaterial "This material demonstrates how to add a material to a database.")
    (vla-put-ActiveMaterial doc oMaterial)
    ;; Display the status of the new layer
    (alert (strcat (vla-get-Name oMaterial) " has been added."
            "\nName: " (vla-get-Name oMaterial)
            "\nDescription: " (vla-get-Description oMaterial)))
GMT+8, 2026-10-27 04:24
