MajorAxis 属性 (ActiveX)
指定椭圆的长轴方向。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双打的三元素阵列) 定义主轴的 3D 矢量。向量起源于椭圆中心。 言论椭圆的长轴称为长轴;较短的是短轴。 ![]() 例子VBA: Sub Example_MajorAxis()
' This example creates an ellipse and finds the major axis
' for that ellipse. It then changes the major axis for the ellipse.
Dim ellObj As AcadEllipse
Dim majAxis(0 To 2) As Double
Dim center(0 To 2) As Double
Dim radRatio As Double
' Create an ellipse in model space
center(0) = 5#: center(1) = 5#: center(2) = 0#
majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
radRatio = 0.3
Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
ellObj.Update
MsgBox "The ellipse has a major axis of " & majAxis(0) & ", " & majAxis(1) & ", " & majAxis(2), vbInformation, "MajorAxis Example"
' Change the major axis of the ellipse
majAxis(0) = 5: majAxis(1) = 5: majAxis(2) = 0
ellObj.MajorAxis = majAxis
ellObj.Update
' Query the major axis of an Ellipse
Dim retMajAxis As Variant
retMajAxis = ellObj.MajorAxis
MsgBox "The ellipse has been udpated with the major axis " & retMajAxis(0) & ", " & retMajAxis(1) & ", " & retMajAxis(2), vbInformation, "MajorAxis Example"
可视化 LISP: (vl-load-com)
(defun c:Example_MajorAxis()
;; This example creates an ellipse and finds the major axis
;; for that ellipse. It then changes the major axis for the ellipse.
;; Create an ellipse in model space
(setq center (vlax-3d-point 5 5 0)
majAxis (vlax-3d-point 10 20 0)
radRatio 0.3)
(setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
(vla-ZoomAll acadObj)
(vla-Update ellObj)
(setq majAxis (vlax-variant-value majAxis))
(alert (strcat "The ellipse has a major axis of " (rtos (vlax-safearray-get-element majAxis 0) 2) ", "
(rtos (vlax-safearray-get-element majAxis 1) 2) ", "
(rtos (vlax-safearray-get-element majAxis 2) 2)))
;; Change the major axis of the ellipse
(setq majAxis (vlax-3d-point 5 5 0))
(vla-put-MajorAxis ellObj majAxis)
(vla-Update ellObj)
;; Query the major axis of an Ellipse
(setq retMajAxis (vlax-variant-value (vla-get-MajorAxis ellObj)))
(alert (strcat "The ellipse has been udpated with the major axis " (rtos (vlax-safearray-get-element retMajAxis 0) 2) ", "
(rtos (vlax-safearray-get-element retMajAxis 1) 2) ", "
(rtos (vlax-safearray-get-element retMajAxis 2) 2)))
GMT+8, 2026-10-27 04:58
