LowerLeftCorner 属性 (ActiveX)
获取当前活动视口的左下角。 支持的平台:仅限 Windows 属性值只读:是的 类型:变体(双精度的双元素数组) 表示当前活动视口左下角的 2D 坐标。 言论and 属性表示视口在显示器上的图形位置。这些属性定义如下:LowerLeftCornerUpperRightCorner ![]() 视口 1— = (0, .5), = (.5, 1)LowerLeftCornerUpperRightCorner 视口 2— = (.5, .5), = (1, 1)LowerLeftCornerUpperRightCorner 视口 3— = (0, 0), = (.5, .5)LowerLeftCornerUpperRightCorner 视口 4— = (.5, 0), = (1, .5)LowerLeftCornerUpperRightCorner 例子VBA: Sub Example_LowerLeftCorner()
' This example creates a new viewport and makes it active.
' Then it splits the viewport into four windows.
' It then finds the lower-left corner of each of the
' windows.
Dim newViewport As AcadViewport
' Create a new viewport and make it active
Set newViewport = ThisDrawing.Viewports.Add("TESTVIEWPORT")
ThisDrawing.ActiveViewport = newViewport
' Split the viewport in four windows
newViewport.Split acViewport4
' Make the newly split viewport active
' Iterate through the viewports. For each viewport,
' make that viewport active and display the coordinates
' of the lower left corner.
Dim entry As AcadViewport
Dim lowerLeft As Variant
For Each entry In ThisDrawing.Viewports
entry.GridOn = True
ThisDrawing.ActiveViewport = entry
lowerLeft = entry.LowerLeftCorner
MsgBox "The lower left corner of this viewport is " & lowerLeft(0) & ", " & lowerLeft(1), , "LowerLeftCorner Example"
entry.GridOn = False
Next
可视化 LISP: (vl-load-com)
(defun c:Example_LowerLeftCorner()
;; This example creates a new viewport and makes it active.
;; Then it splits the viewport into four windows.
;; It then finds the lower-left corner of each of the
;; windows.
;; Create a new viewport and make it active
(setq newViewport (vla-Add (vla-get-Viewports doc) "TESTVIEWPORT"))
(vla-put-ActiveViewport doc newViewport)
;; Split the viewport in four windows
(vla-Split newViewport acViewport4)
;; Make the newly split viewport active
;; Iterate through the viewports. For each viewport,
;; make that viewport active and display the coordinates
;; of the lower left corner.
(vlax-for entry (vla-get-Viewports doc)
(vla-put-GridOn entry :vlax-true)
(vla-put-ActiveViewport doc entry)
(setq lowerLeft (vlax-safearray->list (vlax-variant-value (vla-get-LowerLeftCorner entry))))
(alert (strcat "The lower left corner of this viewport is " (rtos (nth 0 lowerLeft) 2) ", " (rtos (nth 1 lowerLeft) 2)))
(vla-put-GridOn entry :vlax-false)
GMT+8, 2026-10-27 05:15
