LogFilePath 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 799| 评论: 0|原作者: admin|来自: AutoCAD
指定日志文件的位置。
object.LogFilePath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
日志文件的驱动器和路径。
使用该属性可以启用或禁用日志文件功能。LogFileOn
注意:此属性的值存储在 LOGFILEPATH 系统变量中。
Sub Example_LogFilePath()
    ' LogFilePath. It then changes the value, and finally
    Dim currLogFilePath As String
    Dim newLogFilePath As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current LogFilePath value
    currLogFilePath = preferences.Files.LogFilePath
    MsgBox "The current value for LogFilePath is " & currLogFilePath, vbInformation, "LogFilePath Example"
    ' Change the value for LogFilePath
    newLogFilePath = "C:/AutoCAD/"
    preferences.Files.LogFilePath = newLogFilePath
    MsgBox "The new value for LogFilePath is " & newLogFilePath, vbInformation, "LogFilePath Example"
    ' Reset LogFilePath to its original value
    preferences.Files.LogFilePath = currLogFilePath
    MsgBox "The LogFilePath value is reset to " & currLogFilePath, vbInformation, "LogFilePath Example"
(defun c:Example_LogFilePath()
    ;; LogFilePath. It then changes the value, and finally
    ;; Retrieve the current LogFilePath value
    (setq currLogFilePath (vla-get-LogFilePath (vla-get-Files preferences)))
    (alert (strcat "The current value for LogFilePath is " currLogFilePath))
    ;; Change the value for LogFilePath
    (setq newLogFilePath "C:/AutoCAD/")
    (vla-put-LogFilePath (vla-get-Files preferences) newLogFilePath)
    (alert (strcat "The new value for LogFilePath is " newLogFilePath))
    ;; Reset LogFilePath to its original value
    (vla-put-LogFilePath (vla-get-Files preferences) currLogFilePath)
    (alert (strcat "The LogFilePath value is reset to " currLogFilePath))
GMT+8, 2026-10-27 05:20
