LoadAcadLspInAllDocuments 属性 (ActiveX)
指定 acad.lsp 是在启动时加载还是在每个图形中加载。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 注意:此属性的值存储在 ACADLSPASDOC 系统变量中。
例子VBA: Sub Example_LoadAcadLspInAllDocuments()
' LoadAcadLspInAllDocuments. It then changes the value, and finally
Dim currLoadAcadLspInAllDocuments As Boolean
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current LoadAcadLspInAllDocuments value
currLoadAcadLspInAllDocuments = preferences.System.LoadAcadLspInAllDocuments
MsgBox "The current value for LoadAcadLspInAllDocuments is " & preferences.System.LoadAcadLspInAllDocuments, vbInformation, "LoadAcadLspInAllDocuments Example"
' Change the value for LoadAcadLspInAllDocuments
preferences.System.LoadAcadLspInAllDocuments = Not (currLoadAcadLspInAllDocuments)
MsgBox "The new value for LoadAcadLspInAllDocuments is " & preferences.System.LoadAcadLspInAllDocuments, vbInformation, "LoadAcadLspInAllDocuments Example"
' Reset LoadAcadLspInAllDocuments to its original value
preferences.System.LoadAcadLspInAllDocuments = currLoadAcadLspInAllDocuments
MsgBox "The LoadAcadLspInAllDocuments value is reset to " & preferences.System.LoadAcadLspInAllDocuments, vbInformation, "LoadAcadLspInAllDocuments Example"
可视化 LISP: (vl-load-com)
(defun c:Example_LoadAcadLspInAllDocuments()
;; LoadAcadLspInAllDocuments. It then changes the value, and finally
;; Retrieve the current LoadAcadLspInAllDocuments value
(setq currLoadAcadLspInAllDocuments (vla-get-LoadAcadLspInAllDocuments (vla-get-System preferences)))
(alert (strcat "The current value for LoadAcadLspInAllDocuments is " (if (= currLoadAcadLspInAllDocuments :vlax-true) "True" "False")))
;; Change the value for LoadAcadLspInAllDocuments
(vla-put-LoadAcadLspInAllDocuments (vla-get-System preferences) (if (= currLoadAcadLspInAllDocuments :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The new value for LoadAcadLspInAllDocuments is " (if (= (vla-get-LoadAcadLspInAllDocuments (vla-get-System preferences)) :vlax-true) "True" "False")))
;; Reset LoadAcadLspInAllDocuments to its original value
(vla-put-LoadAcadLspInAllDocuments (vla-get-System preferences) currLoadAcadLspInAllDocuments)
(alert (strcat "The LoadAcadLspInAllDocuments value is reset to " (if (= (vla-get-LoadAcadLspInAllDocuments (vla-get-System preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-27 10:29
