Linetypes 属性 (ActiveX)
获取文档的 Linetypes 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Linetypes()
' This example finds the linetypes collection and
' lists all the available linetypes in the collection.
Dim linetypeColl As AcadLineTypes
Dim entry As AcadLineType
Dim msg As String
' Return the linetype collection object of the active document
Set linetypeColl = ThisDrawing.Linetypes
' List all available linetypes
For Each entry In linetypeColl
msg = msg & entry.name & vbCrLf
Next
MsgBox "The linetypes available in this drawing are:" & vbCrLf & msg, vbInformation, "Linetypes Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Linetypes()
;; This example finds the linetypes collection and
;; lists all the available linetypes in the collection.
;; Return the linetype collection object of the active document
(setq linetypeColl (vla-get-Linetypes doc))
;; List all available linetypes
(setq msg "")
(vlax-for entry linetypeColl
(setq msg (strcat msg (vla-get-Name entry) "\n"))
(alert (strcat "The linetypes available in this drawing are:\n" msg))
GMT+8, 2026-10-27 05:20
