LinearScaleFactor 属性 (ActiveX)
指定线性尺寸测量的全局比例因子。 支持的平台:仅限 Windows 签名VBA: object.LinearScaleFactor
属性值只读:不 类型:双 大于 0.0 的实数。 言论此属性的初始值为 1.0000。 当指定负值时,该因子仅应用于图纸空间。要应用的纸张空间系数是此属性的绝对值。LinearScaleFactor 注意:此属性将覆盖给定维度的 DIMLFAC 系统变量的值。
例子VBA: Sub Example_LinearScaleFactor()
' turns on the tolerance display for the new dimension. The LinearScaleFactor
' of the tolerance is then read and modified.
' * Note the change in the text of the dimension after the modification.
Dim dimObj As AcadDimAligned
Dim newText As AcadTextStyle
Dim CurrentScale As Integer
' Define the dimension
point1(0) = 1: point1(1) = 10: point1(2) = 0
point2(0) = 10: point2(1) = 10: point2(2) = 0
' Turn on the tolerance display
dimObj.ToleranceDisplay = acTolSymmetrical
' Display current scale factor
MsgBox dimObj.LinearScaleFactor
' Change current scale factor
dimObj.LinearScaleFactor = 10# ' Multiply by ten
' Display new scale factor
可视化 LISP: (vl-load-com)
(defun c:Example_LinearScaleFactor()
;; turns on the tolerance display for the new dimension. The LinearScaleFactor
;; of the tolerance is then read and modified.
;; * Note the change in the text of the dimension after the modification.
;; Define the dimension
(setq point1 (vlax-3d-point 1 10 0)
point2 (vlax-3d-point 10 10 0)
;; Turn on the tolerance display
(vla-put-ToleranceDisplay dimObj acTolSymmetrical)
(vla-ZoomAll acadObj)
;; Display current scale factor
(alert (rtos (vla-get-LinearScaleFactor dimObj) 2))
;; Change current scale factor
(vla-put-LinearScaleFactor dimObj 10) ;; Multiply by ten
;; Display new scale factor
GMT+8, 2026-10-27 00:42
