Length 属性 (ActiveX)
获取对象的长度。 支持的平台:仅限 Windows 属性值只读:是的 类型:双 线的长度。 言论没有其他评论。 例子VBA: Sub Example_Length()
' This example adds a line in model space and returns the length of the new line
Dim lineObj As AcadLine
Dim startPoint(0 To 2) As Double, endPoint(0 To 2) As Double
' Define the start and end points for the line
startPoint(0) = 1: startPoint(1) = 1: startPoint(2) = 0
endPoint(0) = 5: endPoint(1) = 5: endPoint(2) = 0
' Create the line in model space
MsgBox "The length of the new Line is: " & lineObj.length
可视化 LISP: (vl-load-com)
(defun c:Example_Length()
;; This example adds a line in model space and returns the length of the new line
;; Define the start and end points for the line
(setq startPoint (vlax-3d-point 1 1 0)
endPoint (vlax-3d-point 5 5 0))
;; Create the line in model space
(vla-ZoomAll acadObj)
(alert (strcat "The length of the new Line is: " (rtos (vla-get-Length lineObj) 2)))
GMT+8, 2026-10-27 04:55
