LeaderLength 属性 (ActiveX)
指定引线在直径或半径尺寸上的长度。 支持的平台:仅限 Windows 属性值只读:不 类型:双 领导者的长度。 言论是从尺寸定义指向的距离,到尺寸将对注释文本进行水平狗腿的距离(如果不需要狗腿,则停止)。(有关详细信息,请参阅 or 方法。LeaderLengthChordPointAddDimDiametricAddDimRadial 注意:该设置将仅在创建维度期间使用。保存尺寸后,更改值不会影响尺寸的显示方式。该属性用于计算引线位置。该值不会保存,因此在读取时将始终返回零。LeaderLengthLeaderLengthLeaderLength
例子VBA: Sub Example_LeaderLength()
' This example creates a diametric dimension
' and returns the LeaderLength for that dimension.
Dim dimObj As AcadDimDiametric
Dim chordPoint(0 To 2) As Double
Dim farChordPoint(0 To 2) As Double
Dim leaderLength As Double
' Define the dimension
chordPoint(0) = 5#: chordPoint(1) = 3#: chordPoint(2) = 0#
farChordPoint(0) = 5#: farChordPoint(1) = 5#: farChordPoint(2) = 0#
leaderLength = 1#
' Create the diametric dimension in model space
Set dimObj = ThisDrawing.ModelSpace.AddDimDiametric(chordPoint, farChordPoint, leaderLength)
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_LeaderLength()
;; This example creates a diametric dimension
;; and returns the LeaderLength for that dimension.
;; Define the dimension
(setq chordPoint (vlax-3d-point 5 3 0)
farChordPoint (vlax-3d-point 5 5 0)
leaderLength 1)
;; Create the diametric dimension in model space
(setq dimObj (vla-AddDimDiametric modelSpace chordPoint farChordPoint leaderLength))
(vla-ZoomAll acadObj)
GMT+8, 2026-10-28 04:52
