LayoutID 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 614| 评论: 0|原作者: admin|来自: AutoCAD
指定视图的布局。
object.LayoutID
类型: 查看
此属性应用于的对象。
只读:是的
类型:Long_PTR
布局的 ObjectID。
Sub Example_LayoutID()
    ' This example demonstrates the
    ' CategoryName, LayoutId, LayerState,
    ' and HasVpAssociation properties of the View object
    Dim oLSM As AcadLayerStateManager
    ' Access the LayerStateManager object
    Set oLSM = ThisDrawing.Application. _
       GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(CStr(AcadApplication.Version), 2))
    ' Associate the current drawing database with LayerStateManager
    oLSM.SetDatabase ThisDrawing.Database
    oLSM.Save "ColorLinetype", acLsColor + acLsLineType
    ' Create a view named "New_View" in current drawing
    Dim viewObj As AcadView
    ' Add the view to the views collection
    Set viewObj = ThisDrawing.Views.Add("New_View")
    MsgBox viewObj.Name & " has been added." & vbCrLf & _
           "Height: " & viewObj.Height & vbCrLf & _
           "Width: " & viewObj.Width, , "Example"
    viewObj.CategoryName = "My View Category"
    viewObj.LayerState = "My Layer State"
    viewObj.LayoutId = ThisDrawing.Layouts(1).ObjectID
    MsgBox viewObj.CategoryName & " is the Category name." & vbCrLf & _
            viewObj.LayoutId & " is the Layout ID." & vbCrLf & _
            viewObj.LayerState & " is the Layer state."
    If viewObj.HasVpAssociation = True Then
        MsgBox "The view is associated with a paper space viewport."
    Else
        MsgBox "The view is not associated with a paper space viewport."
   End If
(defun c:Example_LayoutID()
    ;; This example demonstrates the
    ;; CategoryName, LayoutId, LayerState,
    ;; and HasVpAssociation properties of the View object
    ;; Access the LayerStateManager object
    (setq oLSM (vla-GetInterfaceObject acadObj (strcat "AutoCAD.AcadLayerStateManager." (substr (getvar "ACADVER") 1 2))))
    ;; Associate the current drawing database with LayerStateManager
    (vla-SetDatabase oLSM (vla-get-Database doc))
    (vla-Save oLSM "ColorLinetype" (+ acLsColor acLsLineType))
    ;; Create a view named "New_View" in current drawing
    ;; Add the view to the views collection
    (setq viewObj (vla-Add (vla-get-Views doc) "New_View"))
    (alert (strcat (vla-get-Name viewObj) " has been added."
                   "\nHeight: " (rtos (vla-get-Height viewObj) 2)
                   "\nWidth: " (rtos (vla-get-Width viewObj) 2)))
    (vla-put-CategoryName viewObj "My View Category")
    (vla-put-LayerState viewObj "ColorLinetype")
    (vla-put-LayoutId viewObj (vla-get-ObjectID (vla-Item (vla-get-Layouts doc) 1)))
    (alert (strcat (vla-get-CategoryName viewObj) " is the Category name."
                   "\n" (itoa (vla-get-LayoutId viewObj)) " is the Layout ID."
                   "\n" (vla-get-LayerState viewObj) " is the Layer state."))
    (if (= (vla-get-HasVpAssociation viewObj) :vlax-true)
        (alert "The view is associated with a paper space viewport.")
        (alert "The view is not associated with a paper space viewport.")
    (vlax-release-object oLSM)
GMT+8, 2026-10-27 05:24
