LayoutDisplayMargins 属性 (ActiveX)
2024-5-18 16:54| 发布者: admin| 查看: 587| 评论: 0|原作者: admin|来自: AutoCAD
切换布局中边距的显示。
object.LayoutDisplayMargins
类型:首选项显示
此属性应用于的对象。
只读:不
类型:布尔
  • True:边距显示在布局中。
  • False:页边距不显示在布局中。
此属性的初始值为 True。
Sub Example_LayoutDisplayMargins()
    ' This example reads and modifies the preference value that controls
    ' the display of margins in layouts. When finished, this example
    ' resets the preference value back to its original value.
    Dim ACADPref As AcadPreferencesDisplay
    ' Get the display preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Display
    ' Switch to paper space to view this change
    ThisDrawing.ActiveSpace = acPaperSpace
    originalValue = ACADPref.LayoutDisplayMargins
    MsgBox "The LayoutDisplayMargins preference is set to: " & originalValue
    ' Modify the LayoutDisplayMargins preference by toggling the value
    ACADPref.LayoutDisplayMargins = Not (originalValue)
    newValue = ACADPref.LayoutDisplayMargins
    MsgBox "The LayoutDisplayMargins preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.LayoutDisplayMargins = originalValue
    MsgBox "The LayoutDisplayMargins preference was reset back to: " & originalValue
(defun c:Example_LayoutDisplayMargins()
    ;; This example reads and modifies the preference value that controls
    ;; the display of margins in layouts. When finished, this example
    ;; resets the preference value back to its original value.
    ;; Switch to paper space to view this change
    (vla-put-ActiveSpace doc acPaperSpace)
    (setq originalValue (vla-get-LayoutDisplayMargins (vla-get-Display preferences)))
    (alert (strcat "The LayoutDisplayMargins preference is set to: " (if (= originalValue :vlax-true) "True"  "False")))
    ;; Modify the LayoutDisplayMargins preference by toggling the value
    (vla-put-LayoutDisplayMargins (vla-get-Display preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-LayoutDisplayMargins (vla-get-Display preferences)))
    (alert (strcat "The LayoutDisplayMargins preference has been set to: " (if (= newValue :vlax-true) "True"  "False")))
    ;;         this preference in effect
    (vla-put-LayoutDisplayMargins (vla-get-Display preferences) originalValue)
    (alert (strcat "The LayoutDisplayMargins preference was reset back to: " (if (= originalValue :vlax-true) "True"  "False")))
GMT+8, 2026-10-27 05:44
